In the past 20 years, it was common for the indirect emissions from electricity use to account for the majority of a company’s total carbon footprint. Electricity is also typically more expensive than natural gas or fuel oil on an energy-content basis. So, an energy-efficiency program that prioritized reducing electricity use conveniently met both cost and greenhouse-gas reduction goals. It’s often easy, too, to cut electricity consumption with many small measures implemented as an integrated whole.
As the grid moves to a lower-carbon generating mix, an energy manager’s priorities will need to change to meet carbon reduction targets. Already this has happened quickly in some cases. For example, Ontario has eliminated all coal use, ramped up wind and nuclear power use, and now has an emission index less than a quarter the level it was a decade ago. Going forward, direct emissions will account for a much greater portion of a site’s carbon footprint. This forces the thermal side of a plant’s energy use to the forefront – not always the easiest area to tackle.
The relatively rapid reshaping of the power system is creating a new environment for energy managers. Achieving the balance among between cost, carbon, and reliability performance will be much more nuanced, occasionally conflicting and interactive. Technically, there will be greater focus on thermal efficiency, an area that typically needs a longer view, is more capital intensive and can be harder to “sell” to senior management. Managing the interface between physical operational performance and power contract conditions will be essential.
Within one company, energy plans may be significantly different from site to site to meet the same overall goals. Arguably, the biggest challenge for all of us will be to reset our preconceived assumptions as to the appropriate priorities for an effective energy-management plan.
[sidebar id="4"]
