Air compressors are key components in many manufacturing and process industries. Theyre interesting from an engineering standpoint because of the many disciplines involved in their design and application. Also, theyre interesting historically because they are among the earliest machines, and most people have an intuitive understanding of compressor operation. Anyone who has used a bicycle pump or a bellows has operated an air compressor, and they know that work is required to compress air. Anyone knows that compression heats air.
Big picture
The major compressor classes are positive displacement and dynamic. An example of the positive displacement class is the bicycle pump or fireplace bellows, both of which change the volume of a chamber to compress air. If a piston inside a cylinder forms the chamber, the compressor is known as a reciprocating type. These are further subdivided into single-acting and double-acting. In a single-acting type, only one piston face compresses the air; double-acting types use both faces alternately. Reciprocating compressor sizes range from fractional horsepower to more than 600 hp.Another type is the rotary positive displacement compressor, in either helical screw or sliding vane varieties. The helical screw compresses air between a meshing rotating rotor and screw assembly. Helical screw compressors are available in sizes from about 3 hp to several thousand horsepower.
The sliding vane compressor uses a set of sliding vanes placed in slots on a rotor eccentrically mounted in a cylindrical casing. As the rotor spins, centrifugal force presses the vanes against the casing wall to compress air between the vanes and the casing.
The second major compressor class is the dynamic type, which compress by converting air velocity into air pressure using blades mounted on a rotating shaft. In centrifugal compressors, air enters near the base of the impeller blades, accelerates along the blade and exits near the ends of the blades at the circumference of the compressor case. Centrifugal compressors range in size from about 100 hp to several thousand horsepower.
In an axial flow compressor, the air enters and exits along the axis of the shaft, usually after passing through several stages of rotor blades. Each set of rotating blades is separated from the next by nonrotating stator blades. Air compressors in aircraft jet engines are a common example of the axial type. Axial-flow compressors are available in sizes from a few hundred horsepower to several thousand horsepower.
Both positive-displacement and dynamic compressors can be single- or multistage. Multiple stage compressors need two or more stages to reach the final output pressure; the output of one stage being the input to the next. Cooling the air between stages improves compressor efficiency.
Each compressor type reciprocating, screw, rotary vane, centrifugal and axial has typical operating characteristics. There is, however, overlap and, for a given application, one might have a choice of types. Some important characteristics are flow, pressure, capacity control and lubrication.
The output
The higher operating speed and continuous flow through dynamic compressors gives them the greatest flow capacity. Axial units provide the greatest flow capacity, but theres overlap in flow capacity between centrifugal and axial compressors. A rough ranking of the flow capacity of the positive displacement compressors from highest to lowest would be screw, sliding vane and reciprocating, but theres a great deal of overlap.Output pressures from positive-displacement units are similar, with reciprocating units developing the greatest pressure. Within the dynamic compressor family, centrifugal compressors provide greater pressure capabilities than the axial type. Figure 1 shows the approximate range of flow and pressure for various compressor types.
Holding back
Some methods of capacity control are unique to a compressor type, whereas other methods apply to all types. Cylinder unloading is uniquely applied to reciprocating compressors. It controls capacity by delaying the closing of the suction valves so that air drawn into the cylinder can leak back into the suction plenum before compression starts. Keeping the valve open through the entire compression stroke completely unloads the cylinder. More sophisticated systems that allow the valve to close at any time during the compression stroke achieve 100% to 0% capacity variation.Other control schemes for reciprocating compressors include start-stop, variable speed and bypass control (in which compressed air is bypassed to the suction). Vibration and bearing lubrication might limit variable-speed control in reciprocating compressors to about 40% of nominal speed.
Slide valve control is unique to rotary screw compressors. The slide valve varies compressor displacement by returning air back to the suction. Some slide valve applications also vary the discharge port location, which varies the volume ratio. Lift valve unloaders also allow air to return to the suction. The fixed location of the lift valves results in stepped capacity control as opposed to a slide valves stepless control.
Start-stop, suction throttling and variable-speed operation also can control rotary screw compressor capacity. Several manufacturers offer VFD-drive screw compressor packages.
Centrifugal compressors use inlet vane control, which pre-rotates the incoming air to alter the compressors performance curve. Variable-speed control also is effective for centrifugal compressor capacity reduction. Output pressure, however, is proportional to the square of the rotational speed. Inlet vane capacity control results in less of a reduction in pressure output than capacity control using variable-speed control.
Below a minimum flow, air bypass might be necessary to avoid surge conditions. Other types of control methods for centrifugal compressors include suction throttling, adjustable diffuser vanes and movable diffuser walls.
Axial compressor capacity can be controlled with variable-speed drives or with adjustable stator vanes. Continuously variable vanes with automatic control are usually supplied on constant speed applications with frequent changes or fluctuations in operating conditions. With continuously variable stators, a drive ring adjusts the orientation of vanes simultaneously.
Put them to work
Industry finds many uses for compressed air, including air-driven tools, assembly line actuators and drives, powering mold presses, injection molding, process machinery, material transfer, painting, cleaning, blowing, dehydration, vacuum packing and cooling.Small- to medium-sized plants probably use reciprocating, rotary screw and rotary vane compressors. Laboratories that require oil-free air might opt for oilless rotary vane or oilless reciprocating compressors. Plants with high air volume requirements will favor rotary screw, centrifugal and axial compressors. Dry rotary screw, centrifugal and axial compressors can provide high volumes of oil-free air. Many larger capacity applications for centrifugal and axial compressors are found in industries where a process consumes air. This includes air used for combustion, blast furnaces, sewage treatment, compressed-air energy storage, air separation plants and ammonia production.
No seizing allowed
Air compressors can use any of several lubricants: petroleum-based oil, petroleum oil, synthetic blends and completely synthetic lubricant. Lubricant selection depends on the compressor type, service and air quality requirements. Some plants require a lube that is USDA-approved for H-1 application (lubricants with incidental food contact).The compressor lubrication system is dependent upon compressed air quality requirements. Lubricant-free reciprocating compressors dont allow lubricant within the compression chamber. These compressors have heat-resistant, self-lubricating pistons, riders and rings. A distance piece between the crankcase and cylinders prevents crankcase oil from entering the compression chamber. Oilless reciprocating compressors are similar, but without lubricant in the crankcase.
Rotary-screw compressor options are lubricant-injected, dry or water-injected. Lubricant-injected units use the oil to seal the space between the rotating screws, to remove heat and to lubricate the rotors and bearings. Dry-type screw compressors need no lubricant for sealing purposes, operate at higher speeds and provide oil-free air. Water-injected types use water to seal compression chambers internal clearance and to remove heat. The lubricated bearings and gears in both dry and water-injected types are isolated from the compression chamber. Centrifugal and axial compressors use pressure-lubricated bearings and drive gears. Shaft seals isolate the bearings from the compression chamber so that centrifugal and axial compressors can provide oil-free air.
Prime movers
Prime movers for driving air compressors include electric motors, turbines (steam and gas), natural gas, diesel and gasoline engines, in constant speed or variable-speed varieties. Fuel for engines and turbines includes natural gas, landfill gas and sewage treatment gas. Steam turbine drives can be used, particularly if the waste heat from some exothermic chemical process can produce steam.The crystal ball
Air compressors are a mature technology characterized by incremental improvements in specific components and subcomponents. Technology trends are strongly driven by user requirements and by a manufacturers desire to increase market share. A manufacturer might focus on a single compressor type and work to expand its capabilities or might offer a range of compressor types covering the entire market. Some manufacturers might focus on niche industrial markets (manufacturing, oil and gas, chemical) or by performance range (very high pressure, very high flow rate, and so on). The competition is a complex mix; key factors are flow capacity, output pressure capability, air quality, efficiency and, of course, price.Manufacturers hold topics of current research closely, but they are logically driven by the characteristics of each compressor type. Table 1 shows the projected areas of technology development by compressor type. Computers have been an enabling technology in compressor development and application. Finite element analysis finds application in positive displacement and dynamic compressor technology development. Computational fluid dynamic software applied in 2-D and 3-D analysis is providing impetus to continuous improvements in dynamic compressor performance. Computer-based controls are standard on many compressor systems and often include network and Internet capabilities.
Ben J. Sliwinski owns Research Associates, Urbana, Ill. Contact him at [email protected] and (217) 367-2270.
