Ask the Experts: How to achieve compressed air system efficiency gains
In a time of business uncertainty and shrinking budgets, here's the top five actions that compressed air professionals recommend that plants should take to reduce their operating costs.
Aug. 19, 2025
7 min read
Key takeaways
  • Leak detection and repair programs can cut compressed air waste by up to 50%, saving significant energy and costs.
  • Lowering system pressure by just 2 psi reduces energy use 1% and lessens leaks, delivering quick, low-cost efficiency gains.
  • System audits, smart controls, and data monitoring reveal inefficiencies and unlock 10–30% energy savings with strong ROI.
In this Ask the Experts feature, which runs regularly in Plant Services, expert instructors from the Compressed Air Challenge (CAC) tackle questions on compressed air systems and associated technology.
The Compressed Air Challenge, an educational foundation administered by the Compressed Air & Gas Institute, is a voluntary collaboration of industrial end-users; manufacturers, distributors, and their associations; trade organizations; consultants; state research and development agencies; energy efficiency organizations; and utilities. The CAC has one purpose in mind—helping facilities enjoy the benefits of improved performance of your compressed air system.
This month's question: What would your compressed air improvement advice be to a plant manager faced with business uncertainty and shrinking budgets? Can you suggest the top three compressed air improvement actions they should take to reduce their operating costs?
1. Reducing Leaks and Misuse
Ron Marshall (Winnipeg, MB, L1&2 Trainer): Leaks can waste 20 to 40 percent of compressed air in unmanaged systems. Simple methods like soap bubble testing or using a basic ultrasonic leak detector can uncover major losses. Engaging operators in spotting leaks during regular rounds is also effective and free.
Paul Shaw (Berlin, CT, L1&2 Trainer): A major opportunity lies in identifying and fixing air leaks. Leaks can consume a significant amount of a system’s output, and in poorly maintained systems, even more. Using an ultrasonic leak detector to audit your system—especially the last 30 feet of hose drops and tool connections—can uncover hidden losses.
Detection is just the start; fixing the leaks is what delivers savings. Making leak detection and repair a scheduled maintenance task can keep systems running efficiently and reduce energy waste by up to 50%.
Also, eliminating inappropriate uses of compressed air, such as using it for sweeping, cooling, or part ejection, can lead to substantial reductions in demand. These applications are often better served by electric fans, blowers, or other alternatives. A plant-wide usage audit can highlight where compressed air is being misapplied. Combined with training staff to recognize and avoid wasteful practices, this strategy can cut demand by 5-15% or more.
Paul Maguire (Natick MA, L1 Trainer): I often recommend as a first step to eliminate air leaks, which account for significant compressed air loss in many facilities. A leak detection and repair (LDAR) program using ultrasonic leak detectors can recover thousands of dollars in wasted energy annually.
2. Lowering System Pressure
Ron Marshall: Lowering system pressure is another easy win. Many systems run 10-20 psi higher than needed, and reducing pressure by just 2 psi can cut energy use by 1%. A quick pressure mapping exercise helps identify how low you can go without affecting performance. And reducing pressure also reduces leaks, about 1% less flow for every 1 psi in pressure reduction.
Paul Shaw: One of the quickest wins is to lower system pressure. To do this safely, first assess the pressure needs of your equipment, then reduce compressor setpoints in small steps while watching for performance issues. Clearing up restrictions like clogged filters or undersized piping ensures you can reduce pressure without causing problems. Many plants save 3-10% of their compressor energy costs this way with even greater savings possible if a lightly loaded compressor can be turned off entirely.
Paul Maguire: Lowering pressure from 110 to 100 psi could save up to $10,000 per year in a mid-sized plant. Consider this as a primary step to save costs.
Thomas Wilk
Thomas Wilk
editor in chief
