What Is a process pump?
Dec. 13, 2024
Discover the essential functions of process pumps in industrial operations, including product transportation, sanitation, filling, and waste handling.
Process pumps are critical components in many industries, facilitating the movement of various fluids (liquids, slurries, or gases) within production lines. Understanding different pump types, their specific applications and how to select the right one is essential for maintaining product integrity, ensuring operational efficiency, and meeting regulatory requirements.
What are process pumps used for?
Pumps are fundamental to the movement, sanitation, and processing of fluids in various industrial areas, including:
  • Product transportation: Pumps move raw materials like water and other fluids through production systems. In applications such as pasteurization or filtration, pumps must maintain precise flow rates to ensure efficient product movement while preserving quality.
  • Sanitation and clean-in-place (CIP) systems: Sanitation is vital in many industries. Pumps must meet strict hygienic standards and often support CIP systems. These systems allow for the internal cleaning of equipment without disassembly, helping prevent the introduction of bacteria and contaminants during cleaning cycles.
  • Filling and packaging: Pumps are integral to filling and packaging. They ensure the correct amount of fluid enters each package while minimizing waste and maintaining product consistency.
  • Waste and byproduct handling: Wastewater and byproducts generated during production must be efficiently handled to maintain a clean environment. Process pumps help remove waste while ensuring compliance with environmental regulations.
What types of pumps are used in process plants?
Two main types of pumps are commonly used in process plants: centrifugal pumps and positive displacement pumps. Each type offers specific advantages depending on the application.
Centrifugal pumps. Centrifugal pumps are widely used for their efficiency, low cost and simple design. They are particularly suited for handling low-viscosity fluids, such as water, using a rotating impeller to create velocity and convert kinetic energy into fluid movement.
Key characteristics of centrifugal pumps
  • High-flow, low-viscosity applications: Centrifugal pumps suit applications requiring high flow rates and low-pressure demands.
  • Efficiency: These pumps are highly efficient at moving large volumes of fluid, making them ideal for cooling, filtration or transferring liquids over long distances.
  • Risk of cavitation: A primary challenge with centrifugal pumps is cavitation, which occurs when vapor bubbles form in the pump, leading to noise, vibration and potential damage. To avoid cavitation, pumps must be correctly sized within 15% +/- of the best efficiency point, which can be identified on a pump curve.
Positive displacement (PD) pumps. Positive displacement pumps are used for handling higher-viscosity and shear-sensitive fluids. They operate by trapping a fixed amount of fluid and forcing it through the system, making them ideal for more challenging applications like moving thick slurries or products with suspended solids.
Types of PD pumps
  • Rotary lobe: These pumps are designed to move viscous products like creams, syrups, and slurries, helping to maintain product integrity.
  • Diaphragm: Used for precise, low-flow applications, diaphragm pumps can handle various fluid viscosities and chemical compositions.
  • Piston and circumferential piston: Designed for high-pressure applications, these pumps are particularly effective in moving thick, sticky fluids.
Key characteristics of PD pumps
  • Low-flow, high-pressure applications: PD pumps are better suited for low-flow applications that require high-pressure pumping, such as filling operations and moving viscous liquids.
  • Handling shear-sensitive products: These pumps can move products without damaging their structure, which is essential in industries where product integrity is paramount.
  • Sanitation-friendly design: Many PD pumps are CIP-compatible, making them ideal for sanitary environments.
How do I choose a process pump?
Selecting the right process pump involves considering several factors, especially in industries where product sensitivity and hygiene are crucial. The fluid’s characteristics—such as viscosity, temperature and sensitivity—will determine the type of pump needed. For instance:
  • Low-viscosity liquids: Fluids like water are best handled by centrifugal pumps, which efficiently move large volumes at low pressure.
  • High-viscosity products: Liquids such as syrups, creams and slurries require PD pumps because they can handle thicker fluids without compromising flow or pressure.
  • Shear-sensitive products: Items like sauces demand PD pumps that offer gentle pumping action to avoid damaging the product structure.
Flow rate and pressure requirements. Flow rate and pressure are crucial elements in selecting the right pump. Centrifugal pumps are ideal for high-flow, low-pressure systems, while PD pumps are designed for low-flow, high-pressure applications. Proper pump sizing ensures the system meets the required flow rates without causing cavitation or strain.
Pump sizing should always account for factors like flow rate, viscosity, temperature and the system’s desired pressure. Using pump curves and consulting with manufacturers is vital to determining the correct size and avoiding operational inefficiencies.
Sanitary requirements. Sanitation is a top priority in many industries. Pumps must comply with regulatory standards, requiring cleanable surfaces and compatibility with CIP or SIP (sterilize-in-place) processes. Seals and gaskets should also be carefully selected to avoid contamination and leakage.
Maintenance and longevity. Maintenance is another key factor when selecting a process pump. While centrifugal pumps generally require less maintenance due to fewer moving parts, PD pumps may have more components that require regular inspection and replacement.
Total cost. When evaluating a pump, the total cost must be considered, including the initial purchase price, energy consumption, maintenance costs over time and availability of spare parts. For example, a higher upfront investment in a well-suited PD pump may result in lower long-term costs due to higher efficiency and durability in demanding applications.
In conclusion
Choosing the right process pump for industrial applications is a technical task that requires careful consideration of product characteristics, flow and pressure needs, and sanitary requirements. Centrifugal pumps are ideal for high-flow, low-pressure applications, while positive displacement pumps excel in low-flow, high-pressure scenarios where product integrity and sanitation are crucial. By considering factors such as cavitation, maintenance and total cost of ownership, operators can select the best pump for their process needs, ensuring long-term efficiency and reliability in their production lines.
Lance Strenfel
Lance Strenfel is an Industry Segment Specialist at Motion. He primarily focuses on process pumps and related product solutions for the food, beverage and dairy markets. Strenfel has more than 30 years of industry experience, with an extensive background in sales and operations across multiple sectors, including processed foods, high-acid foods, beverages, breweries, dairy, home and personal care, pharmaceuticals and biotech. For more information, visit motionind.biz/3YN8cqE.
