1660318104932 2104danfoss
Industrial product roundup: April 9
April 7, 2021
Don’t miss this week’s new products to keep your facility running efficiently and effectively.
Danfoss VLT AutomationDrive EZ FC 321
The new Danfoss VLT AutomationDrive EZ FC 321 provides variable speed control of all asynchronous and permanent magnet motors, on any industrial machine or production line, and is packed with standard features right off the shelf with no special configuration or customization required. Save energy, improve flexibility, and optimize processes with this intelligent yet simple variable frequency drive designed for easy stocking and fast turnaround.
Learn more
Fluke 377 FC and 378 FC Non-Contact Voltage True-rms AC/DC Clamp MetersAny time an electrician or technician makes a voltage measurement on a live conductor, there is a risk of electrical shock. The new Fluke 377 FC and 378 FC Non-Contact Voltage True-RMS AC/DC Clamp Meters minimize this risk because they are the only clamp meters that make accurate non-contact voltage measurements without test leads. The Fluke 377 FC and 378 FC True-rms clamp meters use Field-Sense technology to make testing faster and safer, all without touching a live conductor. You get accurate voltage and current measurements through the clamp jaw. Simply clip the black test lead to any electrical ground, put the clamp jaw around the conductor and see reliable, accurate voltage and current values simultaneously on the dual display. Learn more
EXAIR’s 1/2 NPT FullStream Liquid Atomizing Spray Nozzle
EXAIR’s new 1/2 NPT FullStream Liquid Atomizing Spray Nozzle provides a full cone spray pattern for pressurized liquids. With a vaneless, tangential flow design, the FullStream has wide open internal features to resist clogging while simultaneously producing uniform distribution in a round pattern with medium to large droplets. The compact right-angle design operates at up to 250 PSIG liquid pressure, and functions seamlessly with liquids containing particulate. With FullStream nozzles, the liquid is supplied directly into the body of the nozzle creating a swirling action within a vortex chamber.
Learn more
Force Control Industries' MagnaShear brake
Force Control Industries' MagnaShear maintenance-free, no-adjustment brake virtually eliminates motor brake downtime. The MagnaShear motor brake employs oil shear technology, providing longer service life in demanding applications like the frequent start/stop cycles seen on cranes, hoists, winches and other equipment. Proven oil shear technology transmits torque between lubricated surfaces – thereby eliminating wear on friction surfaces. \ A patented fluid recirculation system dissipates heat – eliminating heat build-up which is the most common problem in dry braking systems.
Learn more
