Figure 1. Holistic OpEx aligns and optimizes people, processes, and technology with strategic objectives and is supported by a strong metrics program.
An holistic approach to OpEx aligns and then optimizes key resources — people, processes, and technology — with strategic objectives and is supported by a strong metrics program (Figure 1).
Strategic objectives typically focus on a combination of areas, including finance, operations, quality, manufacturing, energy management, and health and safety. However, as mentioned above, the challenge isn't in setting these objectives, it's in pursuing them by putting your resources into action. And optimizing your resources for this purpose takes a tactical, well-thought-out approach.
Let’s examine several important trends within each of these resource categories.
People: We may be moving toward a more automated manufacturing and industrial environment, but, without people at the wheel, all of the technology in the world would be useless. Strong leadership and executive support are critical for any OpEx initiative. It starts with the C-Suite executives — chief quality officer, chief operating officer, chief sustainability officer, and others — getting on board, and that mindset trickles down to the rest of the organization.
Processes: Disparate systems and business processes are slowly becoming a challenge of the past, and closed-loop/end-to-end business processes are the future. It’s imperative that you start to standardize processes globally where synergies exist, making them transparent, compliant, and collaborative across the value chain.
Technology: Whether it’s enterprise quality management software, manufacturing operations management software, enterprise resource planning, industrial energy management software, or another enterprise software solution, there’s a trend emerging whereby companies are beginning to deploy enterprise-wide systems. These deployments leverage a combination of standardized business processes in combination with today’s automation capabilities and software applications to manage the complexities of different manufacturing locations. The resulting communicative and collaborative capabilities are incomparable to the IT disconnect that many companies deal with today.
To optimize the impact of metrics, today’s most advanced companies are harmonizing people, processes, and technology, as well as intelligently streamlining processes, data, and content from across the value chain to the right people and in the right context. It’s often the more granular efforts by different teams across the value chain — working both collaboratively and independently — that amount to aggregate improvements toward strategic objectives.
Once you've achieved the right level of visibility with metrics, one of the most powerful characteristics of a strong metrics program is in its ability to enable continuous improvement. Specific goals for strategic objectives may be met, but in the long run you can always raise the mark for future performance. Without universal metrics visibility, this continuous improvement mentality would be a challenge to even conceive.
The right metrics for your organizations
The right set of metrics can be instrumental in monitoring how effectively those resources are being used and whether a particular resource or set of resources needs to be reallocated, ameliorated, or changed entirely. But it’s important to remember that every organization has its own set of challenges and corresponding strategic objectives. As a result, each will rely on different combinations of high-level metrics, as well as more industry-specific and job role-specific ones.
