The Gorgas Steam Plant is located on the Mulberry Fork of the Warrior River, some 35 miles northwest of Birmingham, Alabama. Its first unit began operation in 1917. It is the oldest coal-fired plant at Alabama Power system, a Southern Company subsidiary. Today, units 6,7,8,9 and 10 provide about 1,250 MW.
In 2002, a selective catalytic reduction (SCR) unit for control of nitrogen oxides was installed on Unit 10, a 750-MW super-critical unit. An Advatech flue gas desulfurization (FGD) system, or “scrubber,” was added in 2007 in the first worldwide attempt to scrub multiple units through one system.
In the Unit 10-B Pulverizer, the vertical shaft thrust bearing supports the weight of the mill rotating parts and the downward grinding force exerted by the grinding rolls. The thrust bearing isn’t designed to withstand any radial loading.
“Lubrication contamination is a big problem,” says James “Pete” Peterson, condition-based maintenance specialist at Alabama Power. “Most of our units are from the ’50s, ’60s and ’70s. A good lubrication program, that includes on-site oil analysis, enables you to trend data on your equipment,” says. “It provides for a rapid response, if needed, and can save big dollars. When combined with other technologies, it can help a plant be the best that it can be.”
The plant uses the CSI 5200 Machinery Health Oil Analyzer from Emerson Process Management with a microscope attachment to check for debris.
