The vibration monitoring system on the pickling line rollers shows equipment status at a glance, allows remote monitoring and diagnosis and alarms via e-mail and telephone if a problem starts to occur.
The system uses wireless technology to transmit machine health data to and over the Internet. When machine vibration, temperature, or any other process parameter exceeds established limits, it provides notification within seconds by e-mail or telephone. As the gateway to the Internet, the ProSmart Communication Module provides a secure connection to the ProNet user interface via LAN, DSL, cell, or 802.11 wireless routers. This wireless architecture reduces installation cost and complexity.
The Worthington system proved its worth one Monday when, on starting up again after a weekend shutdown, “We began to get vibration alarms all over the place,” Patterson recalls. “I got an alarm notification on both voice mail and e-mail that there was a very large radial vibration on the three top rolls. At the time, I didn’t suspect that it was a bearing failure, as no bearing frequencies were present and all three top rolls were reacting in the same manner.”
While Patterson traveled the 90 miles to the plant for further investigation, the pickling process was reduced to half-speed to minimize vibration for the balance of the steel run. Analysis revealed that the hydraulic units, which provide the pressure for the rolls on the steel, were left on through the weekend instead of being raised to the standby position. Leaving the rolls down under pressure caused flat spots on each of the three top rollers. When the rollers resumed production, the flat spots caused damaging vibration on each rotation. The alarm probably saved the bearings on the rollers, Patterson says. “If the process had run at full speed for any length of time without any wireless notification that there was a vibration issue, the bearings would have been torn up.”
Using ProSmart’s advanced diagnostic tools to continuously monitor machine health (locally and/or remotely), and deliver key data directly and wirelessly, allowed Worthington Steel to avoid damage to key rotating equipment. The early warning enabled them to actively manage an equipment problem, thus avoiding the expense of damaged machinery and plant downtime.
