May 2007 Web TOC
May 1, 2007
What's new at www.plantservices.com/thismonth?
Every month, PlantServices.com offers a special page (www.plantservices.com/thismonth) that contains extra content specifically related to articles found in the print edition.  Keep an eye out while you’re flipping through the magazine and you’ll see references to articles, white papers, news etc. related to the articles you’re reading. Bookmark www.plantservices.com/thismonth and peruse all the extras as well as sift through plantservices.com’s archives.
Plant Services magazine extras
Hearing is believing
Bearing upgrades- Don't lose your bearings when planning an upgrade
Upgrading equipment
 - Drive system upgrades
Selection algorithm - Selecting the right bearing
Powertrain PdM - Avoid the rolling thunder
D-Energizers
Find and fix compressed air leaks
Steam systems and efficiency
Assessments
Opportunities
Motor-driven systems
Motor, drive, lighting and power distribution payback calculators
Diaphragm pump savings calculatorNatural gas prices
Crude oil prices
Adopt new directions in industrial lighting
Ceramic lighting - See clearly
Task lighting - Seeing in the best possible light
Invest it wisely
Level 1 audits- Profits and compressed air
Efficiency and loading
 - Load 'em up
Capacity controls - Compressor capacity controls
Baselining - Baselining the compressed air system
VSDs - Drive down the cost of compressed air
Managing a compressor project - When non-standard maintenance becomes a project
Performance determinants - Applying the pressure
Upgrades - Planning air system upgrades
Shuffling the hots
Heat of compression- What does Mother Nature say about cooling hot air?
Heat recovery
 - Air compressor heat recovery is a hot topic
Heat pumps - Almost like free BTUs
Heat transfer fluids - Understanding heat transfer systems
Fight the lightning bolts
www.nfpa.com
www.squared-services.com
www.skm.com
www.pberoncompany.com
www.nascoinc.com
www.masterytech.com
Automate to survive
www.ifr.org
www.roboticsonline.com
http://literature.rockwellautomation.com/idc/groups/literature/documents/pp/9324-pp005_-en-p.pdf
www.rockwellautomation.com/rockwellsoftware/design/rslogix5000/whatsnew.html
www.abb.com/robotics
April 2005 | May 2005 | June 2005 | July 2005 | August 2005 | September 2005 | October 2005 | November 2005 | December 2005 | January 2006 | February 2006 | March 2006 | April 2006 | May 2006 | June 2006 | July 2006 | August 2006 | September 2006 | October 2006 | November 2006 | December 2006 | January 2007 | February 2007 | March 2007 | April 2007
