Documenting and designing heat exchangers
May 25, 2007
You should know about the software and calculations you’ll need to document and design heat exchangers.
Last month, this column featured industrial heat tracing. Look at this month’s exploration as an extension of this hot topic. Anyone who has studied thermodynamics learned that energy flows from hotter to colder objects. Of the three forms of heat transfer, conduction is probably the most common version you’ll deal with in a manufacturing plant. It’s through heat exchangers that we control that flow of thermal energy while we extract as much useful work as it can provide.
One should know the technology that’s available for evaluating and troubleshooting the different types of exchangers. You should know about the software and calculations you’ll need to document and design the units. So, why don’t you please join me for another romp through the digital morass we call the Web in search of practical, zero-cost, noncommercial, registration-free resources that you might be able to use when you’re called upon to discipline a recalcitrant or underperforming heat exchanger? Remember, we search the Web so you don't have to.
The basics
Before we launch into the more complicated Web discoveries, you might want to review some basic information regarding this month’s topic. Send your hot little mousie to www.answers.com/topic/heat-exchanger for a high-level primer on what they are, how they work and where they’re used. The content is on the left side of the screen and you’ll need to block out the annoying irrelevancies on the right side until you’ve scrolled down to about mid-document.
Trust, but verify
It might be necessary to evaluate the continued suitability of your heat exchangers when you change the process operating conditions. Even if operating conditions don’t change or become less severe, it would be wise to have tangible proof that an older heat exchanger, which might have no remaining design corrosion allowance, is still mechanically sound. In either case, you can perform the calculations to ensure that each exchanger element still complies with the various codes and guidelines that apply to exchangers and pressure vessels. So says Carmagen Engineering, Inc., Rockaway, N.J., an independent consulting firm that caters to the oil and gas industries, market segments that use many heat exchangers. The company has posted advice on the subject on its Web site. You’ll need to go to http://carmagen.com/newspub.htm and click on “The Carmagen Engineering Report.” Then, look for the entry titled “To Rerate or Not to Rerate — That Is The Question (Part II).” This article, written by Ray Chao and Doug Stelling, offers suggestions about which mechanical components should be evaluated and what you’ll need to do if the original heat exchanger drawings and calculations have gone missing. It’s a lot of work, but it’s also better to choose safe over sorry.
Spec it right
Heat exchangers involve so many variables it’s a wonder that any of them function well. Four temperatures, two flow rates, metallurgy-dependent heat transfer rates, possible phase transitions, insulating deposits collecting on heat transfer surfaces, and the list goes on. The only constant seems to be the exchanger’s physical size. Nevertheless, it’s possible to match the hardware to the job by using online information posted by The Chemical Engineers' Resource Page, Midlothian, Va. That’s the place to go to learn the 10 questions you should ask if you’re involved in designing or specifying one type of heat exchanger. The Web page presents an iterative approach to matching the thermal duty to the process demands. It’s not necessarily an easy calculation, and success hinges on making an accurate initial guess for the heat transfer coefficient and adopting something the article calls zoned analysis. If this is something you wish to tackle, make your way to www.cheresources.com and click on the “Free Articles” link on the left side. Then, select “Process Design” from the drop-down menu. Look for an article titled “Design Considerations for Shell and Tube Heat Exchangers” near the bottom of the next page. I hope it helps.
Heat load
The early stages of specifying a heat exchanger involve knowing something about how many BTU need to be transferred. The inputs include flow rates, temperatures and physical properties. In the old days, performing the appropriate math required an engineering hand calculator and too much time. But, that’s not the case if you pay a visit to www.freecalc.com/hxfram.htm, where you’ll find an input form that powers a heat exchanger sizing routine provided by Beacon Engineers Inc., Woodinville, Wash. The feature is designed for an exchanger configured for liquid-liquid, gas-gas, gas-liquid, condenser or evaporator service. Plug in the information you know, click the calculate button and the next screen reiterates your input plus gives you the heat load. At this point, you have the option of clicking to get a filled out data sheet. But, thanks to the folks at Intel and Microsoft, anyone can enter the numbers online and get a result in a jiffy but have no idea of the appropriateness, accuracy and precision of the math that goes on behind the scenes. It would be better if Beacon were more explicit about the underlying modeling technique.
Designing the hardware
Calculating the heat load is only the first part of the issue at hand. Keep in mind that most heat exchangers are pressure vessels and, therefore, need to be fabricated in accordance with recognized principles that ensure the safety of anyone in the vicinity. Those principles are enshrined in the ASME code, which Heat Transfer Consultants, Inc., Pleasant Hill, Calif., has reduced to a software package you can download for free. Called PVX – 2007, it’s used for designing and rating ASME pressure vessels, TEMA/ASME heat exchangers and interconnecting piping. As you’d expect with a freebie, the software is hobbled with a maximum internal pressure of 300 psi and temperature of 600°F, and external pressure of 10 psi, tube length of 16 ft., a limited selection of shell diameters and a disabled 3-D export capability. With that said, catch your download at www.htcsoftware.com and use it before its 30-day operating window closes.
Data sheet
You should be documenting heat exchanger details for a variety of maintenance-related reasons. One way to capture the relevant numbers is with a data sheet that captures information about temperatures, flows, the fluid’s physical properties and the construction details for the exchanger itself. An example of such a data sheet is brought to you courtesy of the good folks at EST Heat Exchanger LLC, Baton Rouge, La. Point that mouse at www.esthx.com/datasheet.pdf for a data sheet for shell-and-tube heat exchangers. My guess is that you could easily adapt this concept to any heat exchanger in the plant because only the construction details would vary.
The digital approach
After you’ve seen the mathematics needed to explain the thermodynamics that take place in a heat exchanger, it’s obvious that working the numbers by hand isn’t a particularly economical use of our time. This matter was the hole in the market that Bryan Research and Engineering, Inc., Bryan, Texas, filled quite nicely. The company provides simulation software for the process industry and, wouldn’t you know, the software knows about heat exchangers. Bryan R&E posted some technical articles about the topic that you can access by going to www.bre.com, Click on “Support,” even though hovering over it reveals a drop-down menu. Then, click on “Technical Articles.” When that page opens, enter the phrase “heat exchanger” in the “Search for” box near the middle of the screen, not the search box at the right side (that one searches the entire site, not just the articles). That should return five heat exchanger articles. The two I’d recommend are “Confirm Complex Heat Exchanger Performance” by Scott Fulton and Jay Collie as well as “Increasing Heat Exchanger Performance” by Kevin M. Lunsford. The first focuses on using simulators to analyze heat exchanger networks. The second looks at the thermodynamic and mass transfer phenomena that impose operational limits on shell-and-tube exchangers.
Heat transfer: the movie
Now, if you still want to know more about the nitty-gritty of heat exchanger design equations, you could do far worse than to read “Engineering Data Book II” and “Engineering Data Book III” from Wolverine Tube, Inc., Huntsville, Ala. Specifically, Book II covers 375 pages of basic heat transfer, sensible heat transfer, condensing heat transfer and much more material you probably never saw in college. Break out your engineering calculators, boys. You’re going to need them. But, Book III is far more interesting because it exploits online capabilities through 50 or so videos you can access when you open the first chapter. These mini-movies show examples of the different sorts of single- and multi-phase flow that occur within the tubes of your favorite heat exchanger when it’s operating. Send that inquisitive desk rodent over to www.wlv.com/products and have it scroll down to the “Design tools” entries at the bottom.
Flat is complex
The iLab Heat Transfer Project of the Department of Chemical Engineering at the Massachusetts Institute of Technology uses three styles of heat exchangers — shell-and-tube, tubular and flat plate — as teaching aids. You can learn more than you ever wanted to know about flat plate exchangers by heading off to http://heatex.mit.edu/ and clicking on “Theory” found in the left-hand column. Load the document titled “Theory for Performance of the Flat Plate Heat Exchanger,” by V. F. McNeill and C. K. Colton. It explains why a rigorous analysis of this exchanger type is so complex. Once you get through the high-level math, the 15-page document provides various plots of effectiveness (the ratio of actual to maximum possible heat transfer), theoretical heat transfer units and correction factors. The material here has been applied to the 10-plate exchanger the lab uses, but I suppose it could be generalized to any heat exchanger if you have the computational wherewithal.
On the other hand, you might want to use a somewhat more 21st-century approach by using software to take care of those pesky mathematical details. Believe it or not, there exists at least one package dedicated to the plate and frame exchanger. Not only that, it’s a free download, but with a catch or two. Those simple wrinkles are that once you download it, you better be ready to play with it because it expires in 20 days or 20 uses, whichever comes first, and that it’s crippled relative to the full package that’s for sale. So, if you’re interested in “Gasketed Plate Heat Exchanger Design (PH 2),” a software package produced by WeBBusterZ Engineering Software, you’ll need to zip over to www.download.com/3000-20-10462100.html on the CNET Networks, Inc. Web site.
Something for the home, too
Every little bit helps when it comes to energy conservation, especially if you’re the one footing the bill with after-tax income. The next Web page from Iris Communications, Inc., Lorane, Ore., is too short to merit much coverage here, but it shows a exchanger assembly for recovering heat from waste water. Dribble over to http://oikos.com/esb, scroll down to issue number 49 and click on “GFX Device Recovers Waste Energy From Drain Water.”
Without comment
http://engineeredwriting.com/samples/040440.pdf
www.tema.org/
Now, update the tracking sheet.
