What is conveyor belt maintenance?
Dec. 17, 2024
A well-maintained conveyor belt system is an investment in operational efficiency and enhanced productivity.
Conveyor belts serve as material handling’s essential circulatory system to many industries, ranging from food processing and package handling to harsh mining environments. Rigorous maintenance is vital to ensuring operational efficiency and reducing downtime. This article covers the fundamentals of routine maintenance, common failure points, and belt replacement best practices.
What are the most common failure points of conveyor belts?
Understanding the common conveyor belt vulnerabilities can significantly enhance maintenance strategies and reduce unplanned downtime.
  • Belt splices: Mechanical splices are especially prone to wear and can deteriorate faster than the rest of the belt. Regular inspections and timely replacements are necessary to prevent unexpected failures.
  • Pulley lagging: This layer of material, applied to drive pulleys to improve traction and reduce belt slippage, can wear down over time. Worn or damaged lagging can cause misalignment, decrease tension, and increase the likelihood of belt slippage. Make pulley lagging part of your regular inspection.
  • Rollers and idlers: These components support the belt and maintain its alignment. If damaged or seized up, they can cause excessive belt wear, misalignment, and potential failure. Regular lubrication and inspection of these components are crucial to avoid such issues.
  • Misalignment: Belt misalignment can cause uneven wear and tracking issues. This reduces system efficiency and can significantly damage the belt and other components. Regular alignment checks are essential to ensure the belt runs smoothly within the system.
  • Material buildup: Product debris or material buildup on the belt or other components can lead to belt misalignment, increased wear, and potential system blockages. Regular cleaning and monitoring for material buildup are necessary to prevent these issues.
  • Tension issues: Both excessive and insufficient tension can lead to problems like belt slippage, wear and premature failure of the belt or drive components. Regular tension checks and adjustments are important to maintain system performance.
What should be checked on conveyor belt systems?
Proactive maintenance is the first and most essential step in maximizing conveyor belt lifespan and performance.
  • Regular inspections: Starting with the basics, a well-planned maintenance schedule includes frequent inspections of the tension/take-up area, debris or material buildup, and key components like bearings. Inspections are especially important near the belt splice, the weakest point of the belt. Examine the splice for signs of wear, loosening or the beginning of failure. In addition, check the condition of rollers, pulleys and other conveyor components. Regular inspections are crucial to ensure the longevity and efficiency of the conveyor system.
  • Belt tension and alignment: Proper belt tension is critical to prevent slippage and maintain smooth performance. Tension that is too tight or loose can cause early wear on the belt and drive components. Misalignment typically causes belt failure, leading to belt or component damage. Regular checks and adjustments are vital to establish optimal performance and longevity of the system.
  • Cleaning the Belt and System Components: Cleaning procedures are essential for maintaining the quality of the material being conveyed. Use tools ranging from basic scrapers and brushes to more comprehensive processes such as detergent washes or chemical treatments. In some industries, belts are frequently replaced due to bacterial contamination or stains. Proper containment is critical for avoiding product contamination or excessive cleanup.
  • IIoT monitoring: Integrate electrical components and control systems in the maintenance plan. Cables, sensors and control units help monitor system irregularities, vibration and temperature changes—all early indicators of component failures that can be mitigated or even avoided.
How to determine when a conveyor belt should be replaced
Knowing when to replace a conveyor belt is critical for proper maintenance and minimized downtime. Planned downtime to replace the belt while the old one is still on the system will ensure the most efficient belt replacement process. Frequently checking for these key indicators can save significant downtime and cost.
  • Splices: Track visible signs of wear on the belt splices, especially mechanical splices, which are prone to failure and require regular inspection. Wear signs include the mechanical splice thinning, a link or pin breaking or the fastener opening. Wear on an endless splice appears as the laps begin to open, crack, or buckle from inside.
  • Cover and edge wear: Track belt cover wear, cracks, cuts and gouges that indicate material damage, while tears and frayed edges signal alignment issues. These defects can lead to belt failure if ignored.
  • Delamination: Check for bulges and separation of the belt material, caused by pulley, idler, chemical or moisture damage.
A proactive approach
Maintaining conveyor belt systems involves a comprehensive yet easy-to-implement strategy. By recognizing when a belt needs to be replaced, conducting regular maintenance and addressing the most common failure points, companies can minimize downtime and extend their equipment’s operational life. A well-maintained conveyor belt system is an investment in operational efficiency and enhanced productivity.
Seth Stoner
Seth Stoner is the Director of Product Management for Motion Conveyance Solutions. He has had many roles in his 29 years in the conveyor belting industry. For more information, visit MiConveyanceSolutions.com.
