Adaptive compressed air systems maximize energy efficiency. The Sigma Air Manager (SAM) 2 compressed air master controller from Kaeser Compressors uses 3-D advanced control to orchestrate system performance. It is designed for easy IIoT integration and arrives pre-programmed.
“Compressed air is a plant resource that needs to be managed. That is why SAM 2 was designed with built-in monitoring and on-demand reporting capabilities so compressed air energy usage and power consumption can be continually monitored and audited,” says Timothy Hitzges, product engineer for controls at Kaeser Compressors.
Click here to download a white paper from Kaeser Compressors.
Test tools are also becoming intelligent. Fluke ScopeMeter portable oscilloscopes integrate with the Fluke Connect mobile app to wirelessly transfer waveform signatures from the oscilloscope to the cloud, where they can be viewed, shared, and stored for ongoing analysis.
“Capturing a waveform signature at critical junctions in the control system allows Maintenance to establish a baseline reference. These references can then aid in diagnosing malfunctions by making it possible to identify what changed, or by tracking signature trends, to determine if maintenance or service is imminently due,” says Hilton Hammond, senior application specialist for portable oscilloscopes at Fluke Corporation.
