At the outset, engineers must complete criticality assessments for all assets, where the lowest level reflects an asset that is likely less severe in terms of safety and production consequences, while a high-criticality asset represents an asset that would result in high costs for an organization in terms of maintenance as well as lost production if it were to fail.
As reliability engineers know, the criticality level of an asset typically is determined by carrying out a qualitative criticality analysis, which takes into consideration both the likelihood and the consequence of an asset failure. In addition to this qualitative analysis, a company could consider quantitative risk assessment (QRA) technique, hazards and operability analysis (HAZOP), or what-if analysis to identify worst-case scenarios and associated potential consequences of an asset failure or downtime. These are key data points that are then aggregated with reliability-centered maintenance (RCM) studies as well as root-cause analysis (RCA) reports from prior incidents.
These assessments examine the risk of an asset both at the individual and system level. For instance, a piping segment in a process manufacturing facility handling water could be considered low in safety consequence in the event of a loss-of-containment event. However, if that segment is supplying water to a core secondary process critical to production, it could be considered high in production consequence. How you mitigate risks for the same piece of equipment in one scenario versus the other may be completely different based upon the knowledge that was captured in the criticality analysis.
A strong APM program, derived from true equipment manufacturing and operating knowledge with advanced software algorithms, allows plant operators to incorporate and leverage criticality assessments at scale across an entire plant or fleet within an organization. As assets and equipment age over time, data is ingested and analyzed to constantly update the risk level of each asset through machine learning algorithms.
Maximizing resources to reduce maintenance costs
Standardizing practices around monitoring, classifying, analyzing, and measuring incidents and responses is a fundamental first step in any industrial maintenance and optimization regime. When these plans are maintained and automated in an APM system, operators can identify common failures and issues across sites at a global or regional level, and then zoom in on incremental losses and incidents at individual sites to prevent major problems long term.
Further, APM facilitates the next phase for plant management through operation performance management (OPM), which drives improved operational decision-making to respond to changing plant conditions. With accurate, clear, and complete situational awareness, plant operators and management can maximize business outcomes with improved performance and productivity.
Industrial organizations leveraging a risk-based approach to maintenance activities are realizing cost savings while maximizing resources. As one example, a global mining company supplying advanced equipment, systems, and direct services optimized its maintenance strategies to cut processing time by 75%. A chemical plant producing 780,000 tons of sodium sulfate and 90,000 tons of magnesium oxide each year experienced savings of $4.6 million over five years. Another petrochemical company reduced corrective maintenance by 14% and increased preventative maintenance by 25%.
The return on investment for an analytics-driven maintenance approach with APM is significant, but many organizations today still find themselves reacting to failures or preventing issues that do not yet exist. Collecting and monitoring data in the short term allows reliability and maintenance engineers to optimize scheduled maintenance and better understand the failure modes of the component or asset that is being monitored, but there is still untapped potential.
APM allows users to model the critical elements of the process and the interactions among variables and risks based on criticality and prior failures, identifying patterns and mitigating risks before they occur and ultimately bringing unprecedented value to plant operators in the form of cost savings and increased efficiencies around maintenance activities.
